Date/Time: Thu, 16 Jan 2025 22:01:13 +0000
"Auto Trading Enabled - Chart"
View Count: 1873
[2017-11-23 12:56:08] |
User956467 - Posts: 30 |
I am comfortable using the study "Spreadsheet System for Trading" including sending orders live and simulated. I have created a keyboard shortcut for "Auto Trading Enabled - Chart." Currently, I am using this keyboard shortcut to turn auto trading on and off for each of 16 individual charts as all other settings are "on" for auto trading. Is there a way of getting a button (or something similar) in view on a chart that I can left click to turn "Auto Trading Enabled - Chart" on and off? A button on the chart that turns green when on, and red when off, with a simple left click would be fantastic. Is this possible? The way I am doing it now is risky and too slow with multiple charts. And, there is no visual on the chart to confirm auto trading is on. P.S. I am the guy who requested "Move Targets to Price" and I use that feature everyday to quickly get out of trades that are not going well, at my prices, rather than using a market order. The way it is coded is far better than I imagined. THANK YOU! |
[2017-11-24 02:24:14] |
Yes this is generally possible by using the Control Bar button for this command: Control Bar You can also change Control Bar button properties: Control Bar: Control Bar Button Properties Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-28 11:47:39] |
In "Customize Control Bar 2" >> "Available Control Bar Commands" >> "Trade" I can find "Auto Trading On/Off | AT" (which toggles "Auto Trading Enabled - Global" on/off) but I cannot find "Auto Trading Enabled - Chart." Is "Auto Trading Enabled - Chart" somewhere else or can it be added to "Available ... Commands?" Thank you for your efforts. |
[2017-11-28 20:34:51] |
It looks like we will have to add this. If it is missing we will work on this today.
[2017-11-29 04:49:52] |
This is going to be added to the next release. We will have a new version out, within a day.
