Date/Time: Thu, 16 Jan 2025 20:12:41 +0000
DRAWSTYLE_SUBGRAPH_NAME_AND_VALUE_LABELS_ONLY
View Count: 1068
[2017-11-23 10:27:42] |
User39772 - Posts: 311 |
Hello, I tried to proceed according to: ACSIL Programming Concepts: Displaying Custom Values in the Market Data Columns on the Chart / Trade DOM for debug purposes of single values. It seems that DRAWSTYLE_SUBGRAPH_NAME_AND_VALUE_LABELS_ONLY and other mentioned enums are no longer supported. Is there another way to just print a value into the chart area ? Is it possible to enable/disable DC features from within the study dll, e.g. to enable Auto Trading or to access other sc menues ? If not, is there another way to control sc e.g. via a scripting language ? |
[2017-11-23 19:33:14] |
The DRAWSTYLE_SUBGRAPH_NAME_AND_VALUE_LABELS_ONLY Draw Style absolutely is supported. Refer to: ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].DrawStyle Is there another way to just print a value into the chart area ? Using Drawing Tools From an Advanced Custom Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-24 13:42:04] |
Please see compiler errors: Error C2065 'LL_DISPLAY_CUSTOM_VALUE_AT_Y': undeclared identifier Error C2065 'DRAWSTYLE_SUBGRAPH_NAME_AND_VALUE_LABELS_ONLY': undeclared identifier and your description under ACSIL Programming Concepts scconstants.h does not contain: DRAWSTYLE_SUBGRAPH_NAME_AND_VALUE_LABELS_ONLY or LL_DISPLAY_CUSTOM_VALUE_AT_Y Please send an example how this should work. |
[2017-11-24 20:40:09] |
The problem is you are running an older version of Sierra Chart. Update following these instructions here: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
