Date/Time: Sun, 24 Nov 2024 01:30:32 +0000
center chart
View Count: 1356
[2013-09-13 19:26:37] |
artfuls - Posts: 11 |
their a way keyboard or mouse to center the chart any chart when ts price is lower or higher off the page like by 1 keystroke thanks in advance
[2013-09-16 09:11:04] |
Use Chart >> Reset Chart and then set up a ToolBar button for that command: https://www.sierrachart.com/index.php?l=doc/doc_GlobalSettingsMenu.html#CustomizeToolbar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
