Date/Time: Sun, 24 Nov 2024 01:29:24 +0000
SpreadSheet for trading version 929 to 1024
View Count: 1422
[2013-09-13 19:07:31]
jagoankita - Posts: 24
I trade automatically using spreadsheet for trading on SC v. 929 until now. I would like to know what I should do if I am going to use the "autotrade.scwb" spreadsheet file from that older version to the latest version SC v.1024. Do I have to rewrite all of the spreadsheet cells? Or can I use it as it is?
Thank you.
[2013-09-13 19:15:35]
You should be fine with the update.
One thing that it is important to do is to verify that all of the Study Subgraphs that the formulas reference, are still valid in case there have been any changes with Study Subgraphs outputted to the Spreadsheet. If there any changes, you will need to update those formulas to refer to the correct column.
Date Time Of Last Edit: 2013-09-13 19:16:13
