Date/Time: Thu, 16 Jan 2025 18:51:05 +0000
Flex Renko 541 direction change bar question or bug
View Count: 821
[2017-11-21 23:37:01] |
User360283 - Posts: 506 |
I have enclosed a screen shot of today's ES flex Renko 5-4-1 chart. Note the direction change in the circled area. After the last green bar at 2600.50 the direction changed. During live data, a red bar was painted from 2600.50 to 2599.50. When the next bar began painting, the previous red bar (above) was the deleted. The deletion of the red bar seems odd to me. Is this correct? I would prefer to have the deleted red bar be retained. Thanks |
Attachment Deleted. es renko 541a.png / V - Attached On 2017-11-21 23:36:32 UTC - Size: 207.59 KB - 326 views |
[2017-11-22 00:36:50] |
Update to the current version of Sierra Chart: Software Download: Fast Update And refer to the current documentation here: Renko Bar Charts: Introduction Renko Bar Charts: Renko New Bar Mode Refer to the provided documentation for an understanding of how these work. The appearance of the last bar can change but any bar before the last bar will remain stable. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
