Date/Time: Thu, 16 Jan 2025 20:02:54 +0000
Continuous Charts
View Count: 914
[2017-11-21 19:47:19] |
User841161 - Posts: 230 |
Chart >> Show Rollover Dates. When this option is enabled, then where a new contract month begins in the chart, there is a vertical line and a Month and Year displayed at the bottom of the line. I have a continuous chart here enabled to show rollover dates, but don't see the vertical lines telling me where new contract begins. |
UploadImage.png / V - Attached On 2017-11-21 19:43:07 UTC - Size: 48.41 KB - 277 views Private File Private File |
[2017-11-22 18:36:16] |
This is what we see: http://www.sierrachart.com/image.php?Image=1511375733654.png Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings After that go to the chart and select Chart >> Reload and Recalculate. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
