Date/Time: Thu, 16 Jan 2025 18:51:06 +0000
Is there anyway to disable the alert window?
View Count: 1046
[2017-11-21 12:42:49] |
Mike_S - Posts: 42 |
First off, I love Sierra Chart and I thank you for everything you do. Second, is there anyway to disable the alert window? I tried closing all chartbooks and starting fresh but that didnt work for slowing my alerts down and unchecking the alert tab under Windows doesn't work. Thanks Date Time Of Last Edit: 2017-11-21 17:51:21
[2017-11-21 18:16:17] |
Refer to this setting here: General Settings Window: Show Alerts Log On Study Alert (Global Settings >> General Settings >> Alerts >> Additional Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
