Date/Time: Thu, 16 Jan 2025 19:02:24 +0000
User Request
View Count: 845
[2017-11-20 18:52:41] |
Sierra Chart - Max - Posts: 5779 |
Good afternoon,
I am trying to make the transition from MT4 to SierraCharts but have some points I am unable to do, could you please advise: Attached to email picture on left Sierra and right side MT4 1. Candlesticks differ completely from my MT4 platform which I now are the correct ones by checking in 3 different sources. Changed time zone in Charts Settings but it doesn’t come close to look like right ones? 2. RSI – My default settings in MT4 are: RSI 10 - Applied to Close Moving average - Period 3 - Shift 0 - Method Smoothed Tried applying same values but looks reads different? 3. Stochastics 8,3,3 Close, Close but also reads different? Could you please tell me how I may set these. Thank You Regards https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=14458 https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=14459 Sierra Chart Support |
[2017-11-21 08:28:11] |
1. In the Sierra Chart chart, you have a GBP Forex index.The calculation method that Sierra Chart uses for those is documented here: Sierra Chart Market Statistics: Forex Indexes Calculation What we see in the chart on the right, is different. There is somewhat of a similar appearance, but the values are quite different. We do not know the calculation method that chart is using. 2. For the RSI study use the following Inputs: Last, 10, 3, 70, 30, Smoothed Moving Average. Any differences have to do with the differences of the underlying data as we have explained in item 1 above. 3. For the Stochastic-Slow study use the following Inputs: 8, 3, 3. The other Inputs should be just left at their defaults. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-21 08:29:00
