Date/Time: Thu, 16 Jan 2025 19:15:55 +0000
Linear Regression End Channel
View Count: 1097
[2017-11-20 17:37:57] |
User39772 - Posts: 311 |
Hello, I did not find a ACSIL member function for the indicator mentioned above. How can I use this in an automated trading system ?
[2017-11-20 19:51:56] |
This is explained here: ACSIL Programming Concepts: Using or Referencing Study/Indicator Data in an ACSIL Function Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
