Date/Time: Thu, 16 Jan 2025 18:53:01 +0000
Broker selection
View Count: 821
[2017-11-20 17:16:01] |
User328623 - Posts: 1 |
I consider buying Sierra Chart for my trading. I am trading the main indices: DAX DOW SP500 FTSE Forex pairs Stocks Mainly on intraday basis but also swing trades. I am a little confused about which broker to select for use with SierraChart. Can you help? Best Jakob |
[2017-11-20 19:50:41] |
The only practical choice is going to be Interactive Brokers if this is what you need to do. Refer to: Interactive Brokers Trading Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
