Date/Time: Thu, 16 Jan 2025 18:58:32 +0000
CQG FIX not supported anymore?
View Count: 795
[2017-11-20 16:39:55]
mrad-1 - Posts: 1
Hello, I am in the process of testing Tradovate and asked them if they could setup Sierra Chart with the CQG FIX connection as is recommended by Sierra Chart.
They replied: "CQG no longer supports the FIX (at least this is what they have indicated to us). They have us instructed all Sierra connections are now done using the WebAPI only."
@Sierra Chart Support: Is this true? Is WebApi a good alternative?
[2017-11-20 19:49:33]
CQG FIX is supported.
You can use the CQG Web API only and that is fine.
Just follow through the instructions here:
CQG Trading Platform Service: Setup Instructions
