Date/Time: Thu, 16 Jan 2025 19:13:57 +0000
[Programming Help] - Alert Code
View Count: 733
[2017-11-20 15:33:25]
User114693 - Posts: 3
Hello, is there a code that will check to see if a signal is the same for 15 minutes. For example, at the top of the hour if a candle is green I get an alert. Within a few minutes it will go back to a red candle and the signal is no longer valid. I just need it to watch to signal for a few minutes then give me an alert. Thank you.
