Date/Time: Thu, 16 Jan 2025 19:05:19 +0000
v1644 SCString.Format() corruption
View Count: 906
[2017-11-20 11:52:56] |
DabbaDo - Posts: 148 |
Edit: Ignore this. Started working okay when I rebooted then restarted VS2017. Ugh! This was working for me in some earlier version. SCString tmp = "Test"; tmp.Format("%s", tmp.GetChars()); // tmp is corrupted SCString bad = "Prefix"; SCString good; good.Format("%s %s", bad.GetChars(), "Suffix"); // this is okay "Prefix Suffix" bad.Format("%s %s", bad.GetChars(), "Suffix"); // this gives [garbage] plus "Suffix" Perhaps something changed in my environment? Or maybe this is new behavior? Thanks, Dale Date Time Of Last Edit: 2017-11-20 12:01:00
[2017-11-20 13:15:13] |
Your code is simply unsafe. You should recognize the mistake you are making. You are copying the content of a string and modifying the same string at the same time.
