Date/Time: Thu, 16 Jan 2025 20:05:42 +0000
Workaround to use 'Trailing stop' for an order for a different Symbol
View Count: 957
[2017-11-20 02:31:05]
naqviak - Posts: 22
I am working on an algorithm to use 'Trailing stop' on a different symbol from the main chart but SC does not support this feature. I am getting SCTRADING_UNSUPPORTED_ATTACHED_ORDER (-4). Is there a workaround to use this order type?
Thanks in advance
[2017-11-20 04:53:18]
We can make this work. We will work on that. We will try to get it done in the next few days.
[2017-11-20 05:30:35]
naqviak - Posts: 22
Awesome thx
[2017-11-24 11:45:51]
In the next release you will be able to use any of the trailing stop order types for Attached Orders when submitting an order for a different symbol or trade account.
However, this particular error message indicates you are trying to use more than one target or stop order:
Only one Target and Stop order can be used at most. That limitation will always remain. So you will need to send separate orders for additional targets and stops.
