Date/Time: Thu, 16 Jan 2025 19:01:32 +0000
[User Discussion] - Charts re-set/gone crazy after windows update
View Count: 805
[2017-11-19 17:13:12] |
User78442 - Posts: 260 |
I'm trying to reset but I keep getting: Caught an unhandled exception in c_Chart::WindowProc. Message: 15, wParam: 0, lParam: 0 | 2017-11-19 17:09:21 * Please advise... |
[2017-11-20 14:15:55] |
We cannot help with this. We see you are using Windows 10. If Windows 10 is unstable do not use it. Once again do not use Windows 10. It is proven to be an unreliable and troublesome product. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
