Date/Time: Sat, 26 Apr 2025 15:40:47 +0000
[Programming Help] - ACSIL Interface Members - Functions
View Count: 871
[2017-11-18 20:03:30] |
User39772 - Posts: 311 |
Hello, my understanding is, that with ACSIL I can create my own study or trading systen using c++ and create a dll for SC with Visual Studio compiler. Is that correct ? Question: Can I use all funktions available in Visual Studio e.g. creating interactive dialoges with the user etc. while the dll is running ? Is it possible to create a dll that performs a backtest automatically instead of using the sc backtester ? Is it possible to load market data from within such a dll an run the trading system defined in the same dll on that data ? If yes, can you point to the relevant functions available for that. Thanks in advance ! |
