Date/Time: Tue, 04 Feb 2025 01:53:25 +0000
Colour theme for Sierra Chart App
View Count: 3054
[2017-11-17 18:10:19]
samual sprat - Posts: 343
Look. I'm not one for rainbow colours and making things distasteful and difficult to look at, but the Sierra Chart is probably the only application I run on my machine that cannot be themed. Out of the box it has beautiful black charts and candles that can be tuned to perfection. It really is something to behold. Why not package it with a 'Dark' theme so that the beautiful charts are not surrounded by a an angry white haze?? :) You know I love the app so so much. I think this would give it a cool factor to take on NT in the looks department also. Just saying !
S
Date Time Of Last Edit: 2017-11-17 18:10:49
[2017-11-17 18:52:43]
This really is not totally clear for us.
But in any case, we are going to develop the capability to switch among multiple Graphics Settings configurations easily. Hopefully, this will be out in the first quarter of next year.
[2019-12-19 21:08:57]
User426557 - Posts: 3
Has this been completed yet? In other words, is there a setting in which a "color scheme" can be selected without having to manually change the colors of each part of the chart? For example, I'm looking for an easy way to switch the color to a white background theme with black candlestick bars for bear bars and white bars (with black outline) for bull bars.
[2019-12-20 00:06:24]
Yes, this has been done for awhile now. Refer to the following:
Graphics Settings: Saving and Loading Multiple Graphics Settings Configurations
[2019-12-20 00:56:10]
I see that there is the ability to save a color theme that one has created, but are there pre loaded themes available as well? Like a white setting I mentioned above. Thank you.
[2019-12-20 15:09:49]
John - SC Support - Posts: 37688
No, there are not any pre-loaded themes. You would need to set up your graphics as you want first, then you can save it out.
