Date/Time: Sun, 24 Nov 2024 01:20:15 +0000
Exclude indicator from scale
View Count: 1479
[2013-09-13 14:58:36]
imdtrader - Posts: 26
can anyone please remind me how to setup an indicator so it does not influence scale of the main price chart?
When I use "reset" in price axis I need to see maximum range in price candles. Not including indicator that can be plotted well above price.
Thank you.
[2013-09-13 15:09:01]
Sawtooth - Posts: 4118
Go to each Region 1 indicator and set the Scale to Same As Region.
[2013-09-13 15:20:23]
Thank you. I knew it was easy, but did not remember where to look.
[2013-09-13 18:55:34]
This is documented here:
http://www.sierrachart.com/index.php?l=doc/doc_Scaling.html#BasingScalePriceBars
