Date/Time: Thu, 16 Jan 2025 18:57:48 +0000
[User Discussion] - object ordering
View Count: 981
[2017-11-17 15:34:52] |
ktfroy - Posts: 85 |
I can place studies behind chart bars, however I can not order the objects so that drawings are underneath chart bars but in front of studies. On the 'advanced settings' tab of the 'chart settings' window, the option for drawings underneath main graph is combined with studies. Since studies can individually be placed on top or underneath this is redundant. Can this be rectified? I would like the order of the objects to be price bars on top, then drawing tools, and then studies underneath. Thank you |
[2017-11-17 17:27:03] |
Why is this post labeled "User Discussion"? It is intended for Sierra Chart Support.
[2017-11-17 18:42:14] |
It is not something we are going to take. It is far too involved and not enough requests. This is why it is marked as a User Discussion. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
