Date/Time: Thu, 16 Jan 2025 19:13:18 +0000
NumbersBars in DOM
View Count: 957
[2017-11-17 15:15:07]
nicktrader - Posts: 728
is it possible to add a NB into the DOM with separate columns(i.e. M5)?
Date Time Of Last Edit: 2017-11-17 17:28:09
[2017-11-17 15:25:09]
NumbersBars - Posts: 141
@nicktrader
Just curious, will adding Chart DOM to number bar chart serve the same purpose?
[2017-11-17 18:56:11]
No. You just need to use a standard chart and enable the Chart DOM:
https://www.sierrachart.com/index.php?page=doc/ChartTrading.html#ChartDOM
