Date/Time: Thu, 16 Jan 2025 16:54:09 +0000
Server side OCO/CQG inquiry
View Count: 1116
[2017-11-17 02:40:30] |
User157806 - Posts: 71 |
Question in regards to server side OCO using CQG data feed if the parent order which has attached OCO orders is not filled yet and the internet connection goes down, will the attached orders still be working on the server?
[2017-11-17 04:56:00] |
No, they will not be. But there are Server Side Bracket Orders supported with CQG: CQG Trading Platform Service: What is Included Which would solve this problem and the orders would be working on the server. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
