Date/Time: Thu, 16 Jan 2025 16:54:27 +0000
Documentation nits - sc.MaintainAdditionalChartDataArrays
View Count: 1118
[2017-11-16 19:50:15] |
DabbaDo - Posts: 148 |
Not very important, but... 1. At http://www.sierrachart.com/index.php?page=doc/ACSIL_Members_Variables_And_Arrays.html#scBaseDataEndDateTime there is a link to sc.MaintainAdditionalChartDataArrays which gives a 404. 2. At ACSIL Interface Members - Variables and Arrays: sc.MaintainAdditionalChartDataArrays there is a no reference to the sc.BaseDataEndDateTime[] array, which the earlier link says is turned on by sc.MaintainAdditionalChartDataArrays. Cheers, Dale |
[2017-11-16 20:12:45] |
1. This is corrected. 2. We will check on this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
