Date/Time: Thu, 16 Jan 2025 17:04:18 +0000
Selection of objects
View Count: 910
[2017-11-16 17:43:23]
User215298 - Posts: 20
Hi team hope you are well.
quick question: sometimes I would like to select one object on a chart that is very close to another, at this point a number on all the objects appear but I donĀ“t know how to select it by the number.
Could you please help me with that?
Thanks!
[2017-11-16 18:54:56]
Did you want to erase/delete a drawing, or modify the drawing in some way?
[2017-11-16 18:59:01]
Actually I would like to learn to do both, thanks! :)
[2017-11-16 19:25:35]
Refer to these sections:
http://www.sierrachart.com/index.php?page=doc/Tools.html#ErasingChartDrawings
http://www.sierrachart.com/index.php?page=doc/Tools.html#AdjustChartDrawing
http://www.sierrachart.com/index.php?page=doc/Tools.html#MoveChartDrawing
[2017-11-16 19:36:59]
Ok thanks
