Date/Time: Thu, 16 Jan 2025 16:53:07 +0000
Chart Trading Order Lines
View Count: 1285
[2017-11-16 17:21:48]
007700 - Posts: 43
On the Charts with the "Chart Trading Order Lines" it displays the Price & Qty and the lines
of the Entry & Positions & Exit Targets.......
Is the a way to move the Price&Qty to the Right Edge of the chart window.......?
imageChartTradeLines.jpg / V - Attached On 2017-11-16 17:18:20 UTC - Size: 191.24 KB - 422 views
[2017-11-16 18:00:14]
You can align all of that data to the right including the X cancel button. Refer to:
http://www.sierrachart.com/index.php?page=doc/ChartTrading.html#AlignOrdersPositionToRight
[2017-11-16 18:59:09]
007700 - Posts: 43
Ok I see it now thanks
I have it to the right edge but no lines
Can i have the line from Right to Left
across the chart......?
[2017-11-16 19:12:32]
No, this is not supported.
Instead of right aligning them you could change the Trade Drawings Left Align %.
Date Time Of Last Edit: 2017-11-16 19:13:19
[2017-11-17 01:03:09]
007700 - Posts: 43
Ok got it Thanks
Is it possible to only show on one chart
if multiple charts or open in chartbook.......?
[2017-11-17 04:45:09]
Yes of course. You just need to simply disable these two menu command options:
Trade Menu: Chart Trade Mode On (Trade menu)
Trade Menu: Show Orders And Position (Trade menu)
Date Time Of Last Edit: 2017-11-17 04:45:24
