Date/Time: Sat, 18 Jan 2025 01:49:16 +0000
[Programming Help] - Volume Value Area Lines
View Count: 1360
[2017-11-16 16:48:41] |
User523468 - Posts: 27 |
Hi. I want to create an alert condition when the Volume Value Area Low is at the current low of the day and also when the Volume Value Area High is at the current high of the day.
[2017-11-16 17:58:24] |
Refer to this page: http://www.sierrachart.com/index.php?page=doc/StudyChartAlertsAndScanning.php Are you using the Volume Value Area Lines study? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-16 19:56:51] |
Yes I am using it.
[2017-11-17 20:15:41] |
The formula is : =OR(SG2 = H, SG3 = L) To use this formula, refer to: http://www.sierrachart.com/index.php?page=doc/StudyChartAlertsAndScanning.php#EnterAlertOnStudy Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-21 23:55:58] |
User164231 - Posts: 278 |
Hi, I am new to this and need some help from SC support. How do I create a formula when today's price is within 10 point or less or has pass through previous day POC? Also, it would be nice to have samples of formula created earlier and to explain what they do. This will provide users like myself clues on how to build them. Right now I am totally clueless after going through this; http://www.sierrachart.com/index.php?page=doc/StudyChartAlertsAndScanning.php#EnterAlertOnStudy Thanks. Date Time Of Last Edit: 2018-01-22 12:31:00
