Date/Time: Thu, 16 Jan 2025 17:03:30 +0000
Spreadsheet System for Trading - Trade Order Error
View Count: 1436
[2017-11-16 15:05:33]
User956467 - Posts: 30
I am using the Spreadsheet System for Trading for the first time. The rules I defined have triggered a simulated trade as expected but I am getting the following Trade Order Error (in quotes below) repeatedly in the Trade Service Log.
"Trade Order Error: The order quantity for the Parent is 1 and this is less than the total order quantity of 6 for the Attached Orders. Adjust the order quantities so the parent is greater or equal to the Attached Orders. | 2017-11-16 09:54:29 *"
I have spent a lot of time in your online docs and have not found the solution.
Help pls.
[2017-11-16 18:05:36]
Did you want to use Attached Orders for that automated trade? If not,then uncheck Use Attached Orders on the Trade Window for the chart:
http://www.sierrachart.com/index.php?page=doc/TradeWindow.html#OpeningTradeWindow
Or you need to remove any additional Targets and Stops, so there is not more than one each.
[2017-11-16 18:13:50]
I want the spreadsheet to enter the trade with 6 targets defined in the "Trade Window" with "Use Attached Orders" checked and then manually work the trade. Is this possible?
[2017-11-16 19:04:37]
OK, then what you need to do is set the Order Quantity on the Sheet to 6. Refer to:
http://www.sierrachart.com/index.php?page=doc/SpreadsheetSystemsAlertsAndAutomatedTrading.php#CellJ26_OrderQuantity
