Date/Time: Thu, 16 Jan 2025 19:50:18 +0000
incomplete 4h chart data
View Count: 948
[2017-11-16 13:31:29] |
tommymax8599 - Posts: 4 |
HI there, ive followed your frequently asked questions but had no joy. Basically on all instruments my 240 min chart is incomplete so i cant see the full picture. Have you got any solutions for this?
[2017-11-16 17:36:44] |
Incomplete in what way? Follow the instructions here and post an image of the chart showing the problem: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-22 17:10:19] |
hi the data stream is in complete. It only goes back a few months. ive attached a photo for you http://www.sierrachart.com/image.php?Image=1511370560599.png |
UploadImage.png / V - Attached On 2017-11-22 17:06:19 UTC - Size: 47.92 KB - 312 views |
[2017-11-22 17:23:23] |
Follow these instructions here for this: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
