Date/Time: Mon, 14 Sep 2026 15:25:50 +0000
[Programming Help] - Alert implementation issue on the Standart Deviation of a VWAP
View Count: 1322
[2017-11-16 09:14:06]
User799538 - Posts: 3
Hello Support,
I would like to implement an audio alert for each of the 4 Standart Deviations belonging to a single VWAP.
Therefore, I have tried to insert a specific code for each of these 4 SD: when the price cross one of them, it triggers a specific sounds.
It sounds logic.
The VWAP is ID27.
The problem is that Sierrachart seems to not accept a different code for each SD, which is a specific SG
SD3 TOP is SG6
=CROSSFROMBELOW(ID27.SG6)
=CROSSFROMABOVE(ID27.SG6)
SD3 BOTTOM is SG7
=CROSSFROMBELOW(ID27.SG7)
=CROSSFROMABOVE(ID27.SG7)
> I would like to know if it is possible to allocate a specific amount of RAM Memory on Sierra ?
I am using the last version and it crash regularly even if i have 64 Gb of RAM...
Thanks for your help.
[2017-11-17 19:20:01]
These do not make sense because these cross functions will require two parameters. Refer to the documentation for them:
https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#CROSSFROMABOVE_Function
No not at this time. Maximum is 4 GB.
Date Time Of Last Edit: 2017-11-17 19:20:25
