Date/Time: Thu, 16 Jan 2025 17:09:32 +0000
CQG and server side orders
View Count: 1065
[2017-11-16 03:19:42] |
User859795 - Posts: 51 |
Hello, I'm using CQG Fix Trading live connection (Dorman Trading) and both use server side OCO and bracket orders are enabled in the GLobal settings. However, asking the brokerage they only see the main order on their server, no bracket orders are visible - when the main order is only a pending order. Does it mean that if the order is still a pending order, the bracket orders stay on the platform side and only when the pending becomes a market order (open order), that's when the brackets were sent to the server side? Bracket / OCO orders show "Child-Server" on the chart. Or is it just a bad / false API configuration of CQG on their side? Thank you, Zolie |
[2017-11-16 04:50:01] |
Bracket / OCO orders show "Child-Server" on the chart. Based on this, the orders are on the CQG server. It is not surprising that the broker might not be able to see them though.
