Date/Time: Thu, 16 Jan 2025 17:17:44 +0000
Transact
View Count: 929
[2017-11-15 19:29:52] |
User82486 - Posts: 43 |
I have bee a client for years. I have just opened a futures trading account with Transact and I find that they have made changes to their version of Sierra. I find their version awkward for me after years of knowledge about Sierra Charts and DOM trading platform.. Can I use the standard Sierra with data feed from Transact and trading platform on the regular Sierra DOM?+ How would the connection be compared to the charts and DOM of Transact. I am one of your paying clients and intend to remain so. Using Interactive software because it is free with the brokerage account is not important for me. Fred Epstein |
[2017-11-15 19:41:38] |
Yes you can do this. Just use your existing or new installation of Sierra Chart and set it to use TransAct. Follow the instructions here: https://www.sierrachart.com/index.php?page=doc/TransAct.php#SetupInstructions Here are the instructions to install another copy of Sierra Chart if you want: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-15 19:43:10
