Date/Time: Thu, 16 Jan 2025 17:20:17 +0000
oneup trader connection
View Count: 2299
[2017-11-15 17:13:38]
User126996 - Posts: 30
HI,
I'm trying to connect to rithmic data feed for a oneuptrader.com account. I am not able to connect. here is my log:
Reading Internal Order ID file. | 2017-11-15 10:12:12
Reading Trade Orders file. | 2017-11-15 10:12:12
Reading Trade Positions file. | 2017-11-15 10:12:12
Listening on UDP port 22903. | 2017-11-15 10:12:12
Software version: 1605 | 2017-11-15 10:12:12
Usage end date: 2017-12-16 | 2017-11-15 10:12:12
Enabled for: Advanced Features. | 2017-11-15 10:12:12
Enabled for: Sierra Chart Historical Data Service. | 2017-11-15 10:12:12
Allow Support for Sierra Chart Data Feeds is enabled. | 2017-11-15 10:12:12
Current selected Data/Trading service: CQG FIX Trading | 2017-11-15 10:12:12
Chart Update Interval: 10 | 2017-11-15 10:12:12
Data/Trade Service Settings automatically set. | 2017-11-15 10:12:12
Time Zone: -07:00:00 (MST-07MDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2017-11-15 10:12:12
2017-11-15 10:12:15 Local computer time | 2017-11-15 10:12:12
2017-11-15 17:12:15 Local computer time in UTC | 2017-11-15 10:12:12
2017-11-15 10:12:15 Local computer time in SC Time Zone | 2017-11-15 10:12:12
2017-11-15 17:12:10 Server time in UTC | 2017-11-15 10:12:12
Local computer UTC time and Server UTC time difference: 5 seconds. | 2017-11-15 10:12:12
Program path: C:\SierraChart\ | 2017-11-15 10:12:12
Data Files path: C:\SierraChart\Data\ | 2017-11-15 10:12:12
OS Version Number: 10.0 | 2017-11-15 10:12:12
Locale Setting: C | 2017-11-15 10:12:12
Checking for new symbol settings for service code cqg | 2017-11-15 10:12:12
HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2017-11-15 10:12:12
HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2017-11-15 10:12:12
Requesting symbol settings for service code cqg. Overwrite = on. | 2017-11-15 10:12:12
Received 5 login tokens. | 2017-11-15 10:12:12
Symbol settings received. | 2017-11-15 10:12:16
Processed 1334 symbol settings. | 2017-11-15 10:12:16
CQG FIX: Not connecting to trading server because Username is not specified. | 2017-11-15 10:12:20
CQG FIX Trading | Connecting to server api.cqg.com | 2017-11-15 10:12:20
CQG WebSocket | Connecting to WebSocket server. | 2017-11-15 10:12:20
CQG WebSocket socket (5) | Creating socket. Using TLS 1.2. | 2017-11-15 10:12:21
CQG WebSocket socket (5) | Connecting to IP: 208.48.16.35. | 2017-11-15 10:12:21
CQG WebSocket | Opening WebSocket. | 2017-11-15 10:12:21
CQG WebSocket | Sending WebSocket handshake. | 2017-11-15 10:12:21
CQG WebSocket | Received WebSocket handshake acknowledgment. | 2017-11-15 10:12:21
CQG WebSocket | Web socket state is now open. | 2017-11-15 10:12:21
CQG FIX Trading | WebSocket connected. | 2017-11-15 10:12:21
CQG FIX Trading | Sending market data logon message. | 2017-11-15 10:12:21
CQG FIX Trading | Market data logon unsuccessful. Server message: This Trader is not active. Please contact your FCM. | 2017-11-15 10:12:21 *
CQG WebSocket socket (5) | Adding bytes from final send buffer from buffered socket: 8 | 2017-11-15 10:12:21
CQG WebSocket socket (5) | Initiating close of socket by core. | 2017-11-15 10:12:21
CQG WebSocket | WebSocket closed. | 2017-11-15 10:12:21
CQG WebSocket socket (5) | Sending bytes from final send buffer: 8 | 2017-11-15 10:12:21
CQG FIX Trading | WebSocket closed. | 2017-11-15 10:12:21
CQG WebSocket socket (5) | Write in progress. Shutdown being delayed. | 2017-11-15 10:12:21
CQG FIX Trading | Disconnected. | 2017-11-15 10:12:21
HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2017-11-15 10:12:21
HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event | 2017-11-15 10:12:21
HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2017-11-15 10:12:21
HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-11-15 10:12:21
HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2017-11-15 10:12:21
CQG WebSocket socket (5) | Write has completed. Shutdown being performed. | 2017-11-15 10:12:21
CQG WebSocket socket (5) | Shutdown started. Waiting for graceful close. | 2017-11-15 10:12:21
CQG WebSocket socket (5) | Socket gracefully closed by remote side. | 2017-11-15 10:12:21
CQG WebSocket socket (5) | Closed. | 2017-11-15 10:12:21
HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2017-11-15 10:12:21
HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event | 2017-11-15 10:12:21
HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2017-11-15 10:12:21
HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-11-15 10:12:21
HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2017-11-15 10:12:21
Checking for new symbol settings for service code rim | 2017-11-15 10:12:31
Current selected Data/Trading service: Rithmic Trading | 2017-11-15 10:12:31
HTTPS connection to www.sierrachart.com:443 (6) | Creating socket. Using TLS 1.2. | 2017-11-15 10:12:31
HTTPS connection to www.sierrachart.com:443 (6) | Connecting to IP: 204.15.192.108. | 2017-11-15 10:12:31
Requesting symbol settings for service code rim. Overwrite = on. | 2017-11-15 10:12:31
Symbol settings received. | 2017-11-15 10:12:31
Processed 1054 symbol settings. | 2017-11-15 10:12:31
Rithmic Trading | Port for executable: 49177 | 2017-11-15 10:12:36
Listening socket (1160), port 49177 | Closed. | 2017-11-15 10:12:36
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-11-15 10:12:36
HTTPS connection to www.sierrachart.com:443 (6) | Socket gracefully closed by remote side. | 2017-11-15 10:12:36
HTTPS connection to www.sierrachart.com:443 (6) | Received socket Close event | 2017-11-15 10:12:36
HTTPS connection to www.sierrachart.com:443 (6) | Initiating close of socket by core. | 2017-11-15 10:12:36
HTTPS connection to www.sierrachart.com:443 (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-11-15 10:12:36
HTTPS connection to www.sierrachart.com:443 (6) | Closed. | 2017-11-15 10:12:36
Rithmic Trading | Bridge process is running. | 2017-11-15 10:12:38
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49177 | 2017-11-15 10:12:38
DTC Client (7) | Creating socket. | 2017-11-15 10:12:38
DTC Client (7) | Connecting to IP: 127.0.0.1. | 2017-11-15 10:12:38
Rithmic Trading | Connected to server. | 2017-11-15 10:12:38
Rithmic Trading | Starting socket receive thread. | 2017-11-15 10:12:38
Rithmic Trading | Sending Encoding Request to server | 2017-11-15 10:12:38
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-11-15 10:12:38
Rithmic Trading | Sending logon request message. | 2017-11-15 10:12:38
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-11-15 10:12:38
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-11-15 10:12:38
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2017-11-15 10:12:38
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-11-15 10:12:39
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2017-11-15 10:12:39
Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2017-11-15 10:12:39
Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2017-11-15 10:12:39
Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2017-11-15 10:12:39
Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2017-11-15 10:12:39
Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2017-11-15 10:12:40
Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2017-11-15 10:12:40
Rithmic Trading | Received logon response. | 2017-11-15 10:12:40
Rithmic Trading | Server Name: SC DTC Bridge. | 2017-11-15 10:12:40
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2017-11-15 10:12:40
Rithmic Trading | Successfully connected. IB='OneUpTrader', Firm='OneUpTrader'. | 2017-11-15 10:12:40
Rithmic Trading | Trading is supported. | 2017-11-15 10:12:40
Rithmic Trading | Order cancel and replace is supported. | 2017-11-15 10:12:40
Rithmic Trading | OCO Orders supported. | 2017-11-15 10:12:40
Rithmic Trading | Connected to data and trading server. | 2017-11-15 10:12:40
Rithmic Trading | Connection to non-affiliated broker not allowed. | 2017-11-15 10:12:40 *
Connection to the external service has been lost. | 2017-11-15 10:12:40
DTC Client (7) | Initiating close of socket by core. | 2017-11-15 10:12:40
Rithmic Trading | Disconnected. | 2017-11-15 10:12:40
DTC Client (7) | Shutdown started. Waiting for graceful close. | 2017-11-15 10:12:40
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-15 10:12:40
DTC Client (7) | Socket gracefully closed by remote side. | 2017-11-15 10:12:40
DTC Client (7) | Closed. | 2017-11-15 10:12:40
Rithmic Trading | Port for executable: 49193 | 2017-11-15 10:12:42
Listening socket (1288), port 49193 | Closed. | 2017-11-15 10:12:42
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-11-15 10:12:42
Rithmic Trading | Bridge process is not running! | 2017-11-15 10:12:44
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49193 | 2017-11-15 10:12:44
DTC Client (8) | Creating socket. | 2017-11-15 10:12:44
DTC Client (8) | Connecting to IP: 127.0.0.1. | 2017-11-15 10:12:44
DTC Client (8) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-11-15 10:12:45 *
DTC Client (8) | Initiating close of socket by core. | 2017-11-15 10:12:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-11-15 10:12:45
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-15 10:12:45
DTC Client (8) | Closed. | 2017-11-15 10:12:45
Rithmic Trading | Disconnected. | 2017-11-15 10:12:45
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-15 10:12:45
Rithmic Trading | Port for executable: 49195 | 2017-11-15 10:12:47
Listening socket (616), port 49195 | Closed. | 2017-11-15 10:12:47
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-11-15 10:12:47
File >> Disconnect selected. | 2017-11-15 10:12:48
Rithmic Trading | Disconnected. | 2017-11-15 10:12:48
[2017-11-15 18:22:49]
This is the reason for the problem:
This issue is now resolved for you.
Date Time Of Last Edit: 2017-11-15 18:24:26
