Date/Time: Thu, 16 Jan 2025 17:15:10 +0000
Limit orders not working
View Count: 729
[2017-11-15 16:10:33] |
User85924 - Posts: 3 |
Dear Sierra suppot team, There is a problem with my limit orders. When I try to place them to LIVE environment, it doesn´t work. However, when I place them in sim mode, it is ok. Could you please advise/help with the fix immediatelly? I´ve also installed the newest version of Sierra and the problem is still there. Many thanks Sona |
[2017-11-15 18:25:09] |
Do you see any error message displayed in Trade >> Trade Service Log when you submit the limit order? Refer to: Trading Information Windows: Trade Service Log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
