Date/Time: Thu, 16 Jan 2025 16:52:43 +0000
Where to rollback
View Count: 773
[2017-11-15 14:44:43] |
User23815 - Posts: 210 |
On this past monday I installed version 1641. The changes in this version upset my current Flex Renko settings as well as somehow altered the function of my Spreadsheet alerts. I don't know what version I was last on. What version do I need to rollback to in order to return to proper functionality of my bars and spreadsheets prior to your changes? And where is the best place to find documentation on the changes so that I can understand and update my settings to match the new SC versions going forward. Thanks
[2017-11-15 18:40:01] |
You need to use any version prior to 1623. Refer to: Software Download: Software Rollback Procedure Here is the documentation for the current Renko bar functionality: Renko Bar Charts: Introduction Changes are documented here: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer1623 We think you posted before about this and in regards to the true Open and Close prices, there have been no intended changes and if there is a difference, it means the prior versions were not correct. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
