Date/Time: Thu, 16 Jan 2025 17:08:49 +0000
Preset an alert configuration
View Count: 836
[2017-11-15 11:55:16] |
grantx - Posts: 244 |
Something I find annoying is having to configure the alert conditions every time I set one up for a level. So you know how you have your 'tool config' presets? It would be great if you could do the same thing for alerts. I would like to simply right click a line and apply a preset alert condition from a shortcut. Is this possible at the moment? |
[2017-11-15 18:51:46] |
All that is available is what is documented here: Chart Drawing Tools: Configuring a Default Chart Drawing Alert Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
