Date/Time: Thu, 16 Jan 2025 18:55:00 +0000
Renko bars always show as Renko Bricks with Wicks
View Count: 1391
[2017-11-15 11:45:03]
Viacheslav Malafeev - Posts: 88
Thank you for elaborating on Renko bars functionality. I've been working with those bars for years and now it's even better!
However, I noticed long ago that when I'm changing Renko bar period using a keyboard command (let's say 10-9-3fr), graph draw type immediately changes to the default renko draw type, which is Renko Bricks with Wicks. The same thing happens when switching to Renko bars from another bar type. I would like to switch this option off by default, as I am always working with Candlesticks. It's quite inconvenient to go to chart settings every time I choose renko bars.
Thank you.
Date Time Of Last Edit: 2017-11-15 11:49:37
image2017-11-15_14-43-31.png / V - Attached On 2017-11-15 11:44:33 UTC - Size: 79.31 KB - 315 views
[2017-11-15 17:33:42]
We will have to see about this. There really is not an easy solution to this.
It could only potentially be supported with Control Bar buttons where we allow specifying the Graph Drawn Type for custom bar periods.
[2017-11-15 20:12:10]
But why do renko bars necessarily have to change graph draw type?
[2017-11-20 16:05:05]
What we are able to do in the short term and have done, is that as long as the chart bars remain as Renko, the Graph Draw Type will not change.
This will be out in the next release.
Date Time Of Last Edit: 2017-11-20 19:01:40
[2017-11-20 16:30:13]
that's exactly what I was talking about, thanks.
[2017-11-20 19:01:27]
OK then this is resolved.
