Date/Time: Sun, 24 Nov 2024 04:32:30 +0000
same chart,two price lines on differene Time Frame
View Count: 1335
[2013-09-13 07:45:04]
User45578 - Posts: 49
it is easy to put on the same chart two prices lines one upon the oyher even they are of differents time frame ,ok?;but how getting the same scale time above all?thanks for answer
imagePRIX ONLY.PNG / V - Attached On 2013-09-13 07:44:14 UTC - Size: 159.37 KB - 446 views
[2013-09-17 05:14:31]
Refer to help topic 28 to overlay a price graph from a different timeframe:
https://www.sierrachart.com/index.php?l=doc/helpdetails28.html
There will be only one shared timescale since the times are synchronized between the two charts.
