Date/Time: Thu, 16 Jan 2025 17:06:43 +0000
Api or third party software to block computer
View Count: 1154
[2017-11-15 08:22:45] |
User252419 - Posts: 235 |
Hello, Is there any API or third party software that can close and block my computer once I hit my Max Daily Loss Limit? I'm using Global P/L management Lock Trading, but I'm able to easily unlock it once I hit it. Thank you |
[2017-11-15 08:48:17] |
No there is not.
[2017-11-15 12:28:12] |
User883949 - Posts: 6 |
Hi, if you are trading futures, please contact me pz@infinityfutures.com and I can explain how we may be able to assist with this. -Patrick
