Date/Time: Thu, 16 Jan 2025 17:09:52 +0000
task bar at top of chart page detached and missing
View Count: 730
[2017-11-15 01:55:37] |
Don H - Posts: 31 |
Somehow detached the task bar that is normally atop chart pages that contains the shortcuts click onto link features and it's disappeared . Is there way to find and reattach it to appear again
[2017-11-15 05:02:34] |
Are you referring to the Control Bar?: Control Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
