Date/Time: Thu, 16 Jan 2025 17:07:52 +0000
Combine two different symbols
View Count: 1666
[2017-11-14 23:01:39] |
User62448 - Posts: 13 |
Hello :) Is there a way to combine two different symbols on one chart by creating a custom symbol or studie? I would like to calculate with the data by, for example, subtracting the closing prices of the different bars. I would be very grateful if you could help me with this! Is maybe this article paving the right way? Referencing Other Time Frames and Symbols When Using the ACSIL Thanks! |
[2017-11-15 05:12:12] |
Use the Difference (Bar) study: Difference (Bar or Single Line) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-15 10:29:26] |
Absolutely wonderful, thank you for your reply! Your platform is awesome!
