Date/Time: Thu, 16 Jan 2025 16:51:15 +0000
CTS T4 trading dom depth
View Count: 902
[2017-11-14 15:58:56] |
ElPotifor - Posts: 4 |
Hello! Now i've just registered to topsteptrader combine and they gave me cridentials from cts t4 to connect to Sierra.But there is a problem.Market depth is only 10tick for crude oil wti,but i used to trade with at least 50tick Dom by rithmic demo ,for example. They say that the problem is in sierra and they want you to confirm that its not possible to get more dom depth using CTS.Then the will change my combine cridetials from ctst4 to rithmic. I attach both screenshots :dom depth for cts and rithmic demo . Help me please. |
ritmic dom.png / V - Attached On 2017-11-14 15:58:28 UTC - Size: 58.48 KB - 351 views cts dom.png / V - Attached On 2017-11-14 15:58:35 UTC - Size: 39.9 KB - 370 views |
[2017-11-14 19:10:14] |
Refer to this section here about this: https://www.sierrachart.com/index.php?page=doc/CTS_T4.php#MarketDepthData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
