Date/Time: Thu, 16 Jan 2025 16:55:24 +0000
Problem with CQG Datafeed
View Count: 818
[2017-11-14 15:14:06]
Luke - Posts: 142
The CQG Datafeed has been freezing every couple of minutes today, each time I had to manually disconnect and reconnect several times for it to work again (Cbot\YM). There doesn't seem to be any problem with my internet connection.
There have been issues with the CQG feed before, so I'm thinking about subscribing to the SC feed for data, but what about the order routing? Do problems with the CQG datafeed indicate that there might also be problems with orders routed through CQG?
[2017-11-14 18:53:38]
Yes. But you have two choices for order routing. The CQG Web API or CQG FIX Trading.
Refer to:
CQG Trading Platform Service
Here is the documentation for the Sierra Chart Exchange Data Feed:
