Date/Time: Thu, 16 Jan 2025 17:13:02 +0000
filter the volumes
View Count: 1163
[2017-11-14 13:47:06] |
User00111 - Posts: 111 |
How do I filter the volumes above ..... as the attached figure
Footprint Volume.png / V - Attached On 2017-11-14 13:45:25 UTC - Size: 37.48 KB - 337 views |
[2017-11-14 18:03:36] |
We do not understand the question.
[2017-11-14 18:34:55] |
I would filter buyers or seller who place orders over 200 lots
[2017-11-14 19:01:09] |
Refer to: Chart Settings: Volume Filter (Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
