Date/Time: Thu, 16 Jan 2025 16:54:29 +0000
spread - 3 chart broken after increasing "Days to Load"
View Count: 1284
[2017-11-14 03:34:32]
User71961 - Posts: 144
using SC version 1605
i have a chart using the spread - 3 study, dependent on 2 other charts in the workbook at 5 sec update times, and it works fine
Then, when i go into chart settings --> days to load and increase from 300 days to 600 days, my spread -3 chart breaks, and one of the charts on which the spread -3 chart depends is now empty, where it used to be filled with data.
how do i fix this?
[2017-11-14 04:09:42]
Go to this chart. Precisely what is the problem with it? So you saying it is completely blank?
Is it a Historical or Intraday chart?
Date Time Of Last Edit: 2017-11-14 04:11:04
[2017-11-14 15:11:31]
as of the moment i hit "ok" after increasing the Days to Load, the chart became empty. It lost all previous data (this is an intraday chart where the period is set to 5 seconds). I see this chart filling with new data going forward...but it did not load any historical data when i tried to increase DaysToLoad...rather...it just deleted all the data and did not load up the 600 days of history like i expected.
This is Chart 3 Number (ln:5) that i'm referencing in the Spread 3 Chart Study.
[2017-11-14 16:34:50]
i think i found the problem...my PC has 16 gigs of RAM....but my SC instance has 8 chartbooks open, each with a lot of data...and i think i was running out of memory. So i tried to increase the DaystoLoad with only this one chartbook open, and it works.
[2017-11-14 18:20:26]
Yes, Sierra Chart is running out of memory.
Refer to:
Working With Charts: Out of Memory Condition
