Date/Time: Thu, 16 Jan 2025 16:27:57 +0000
RSI configuration settings to duplicate to MT4/5 RSI Indicator
View Count: 1864
[2017-11-13 23:21:05] |
User369868 - Posts: 6 |
On other platforms, like MT4, I'm used to the RSI indicator only having one input and showing one line. The default period is usually 14. I have not figured out how to modify the Sierra Chart RSI settings to show a single line which would duplicate the RSI indicator in MT4/5. https://www.metatrader5.com/en/terminal/help/indicators/oscillators/rsi. I suspect it is a matter of understanding the double line indicator in Sierra Chart. Thank you for your help. |
[2017-11-14 04:39:34] |
The second Subgraph is the RSI average. You can hide it by setting its Subgraph Draw Style to Ignore. Refer to: Chart Studies: Subgraphs Tab >> Draw Style Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
