Date/Time: Thu, 16 Jan 2025 16:10:26 +0000
excel list of symbols
View Count: 874
[2017-11-13 21:13:17] |
madra - Posts: 109 |
Hello Thank you for continuing support. If I have an excel list of symbols would it be possible to export the list to an associated watch list? Thank you |
[2017-11-14 07:17:06] |
Yes. Refer to: Changing the Symbol of a Chart: Importing a List of Symbols The format needs to be in a text format. Not excel. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
