Date/Time: Thu, 16 Jan 2025 16:27:35 +0000
Chart Version
View Count: 840
[2017-11-13 20:35:12]
User123235 - Posts: 46
In my second instance of Sierra Chart, I cant download the current version. It stays stuck at version 1623 even after I download and restart. However, the first instance is updated with the current version. Any fix?
[2017-11-13 21:25:51]
How are you running this second instance. Are you using File >> New Instance?
[2017-11-13 21:41:52]
No. I created a new folder and copied and pasted data folder to new folder.
[2017-11-13 21:45:24]
OK, here are the instructions to update:
We need to know at what point you are encountering a problem. When the installer is run and you go through the installation process, is the installation apparently completing successfully?
Date Time Of Last Edit: 2017-11-13 21:45:41
