Date/Time: Thu, 16 Jan 2025 16:18:37 +0000
TPO Study
View Count: 933
[2017-11-13 16:45:58]
User294366 - Posts: 7
Is it possible to have both the TPO Point of Control and the Volume Point of Control Highlighted on the same TPO Chart?
Thanks Dave
[2017-11-13 18:07:11]
Rino - Posts: 124
They probably have a better solution but you can have
the VbP study under (aligned) with/the TPO and have the transparency set at 100%.
TPO study based on Volume set to no.
This is just if they don't.
image1 aaaa.jpg / V - Attached On 2017-11-13 18:05:06 UTC - Size: 179.95 KB - 309 views
[2017-11-13 19:34:52]
Really the only way to do this is to add the Volume by Price study to the TPO Profile Chart which can then be set to highlight the Volume Point of Control. Refer to:
Time Price Opportunity (TPO) Profile Charts: Displaying Volume Profiles
Date Time Of Last Edit: 2017-11-13 19:35:17
