Date/Time: Thu, 16 Jan 2025 17:12:19 +0000
New version caused unexpected coloring for Numbers Bars study
View Count: 786
[2017-11-13 16:33:58] |
JirkaEspace - Posts: 12 |
After SierraChart upgrade to the newest version 1641, the coloring method for Numbers Bars has changed with unexpected results. There was more complex change of Numbers Bars setup with version 1558 (?) but it seems that "something" has changed again but it is not documented anywhere. Please can you help me: what do I have to change in the setup of Numbers Bars study to get the same results like with the older version of SierraChart? Please see the printscreen attached. It seems that the change is from version 1635+ probably. Date Time Of Last Edit: 2017-11-13 16:51:07
SC_NB_colors.png / V - Attached On 2017-11-13 16:30:23 UTC - Size: 189.66 KB - 286 views |
[2017-11-13 17:58:46] |
John - SC Support - Posts: 37283 |
Yes, there was a change to the Numbers Bars when using the Text Coloring Based on Diagonal Dominant AskVol BidVol Percentage. Previously, it was not coloring the text sides based on whether they were dominant, it was just coloring both sides at all times, except when there was a comparison to 0. This was inconsistent with both the name of this coloring and the other Diagonal Dominant coloring options. The change now makes this consistent with the other options, where now each side will only be colored if it is diagonally dominant. For more information, see the documentation here: Numbers Bars: Text Coloring Based on Diagonal Dominant Side AskVol BidVol Percentage For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-13 17:59:25
[2017-11-14 10:21:13] |
Thank you for quick help. Now it is clear. One idea what would be fine - to be able to setup historical pullback text colour different to default text color. Now it is not possible. If I change default text colour (to change the colour of the not-dominant text of Numbers Bars), the historical pullback colour changes too...
[2017-11-14 18:21:59] |
We will see about this.
