Date/Time: Thu, 16 Jan 2025 16:05:49 +0000
'Cut drawing here' option
View Count: 989
[2017-11-13 13:38:05] |
grantx - Posts: 244 |
If I have a horizontal line/Ray across my chart and I right click on it and select 'cut drawing here' - the line gets cut but removes everything to the right of the chart. I want the line to remain as a horizontal ray projecting forward and remove everything to the left. How do I achieve this? |
[2017-11-13 18:08:36] |
This is simply just not supported at all in the way that you are doing it. Instead you need to adjust the beginning anchor point of a Horizontal Ray to where you want it. Refer to: Chart Drawing Tools: Adjust Drawing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-13 18:09:34
