Date/Time: Thu, 16 Jan 2025 16:08:15 +0000
Market Depth Historical & Profil of indicators selection
View Count: 1129
[2017-11-13 12:33:00] |
User799538 - Posts: 3 |
Sir, I would like to know that the Market Depth Historical Datas indicator does not work anymore after 20mn of use. Is this normal ? Besides, I would like to know if it is possible to save a selection of indicators as a profil to import them into another chart to avoid a manual import of each of them ? Thanks. |
[2017-11-13 19:46:13] |
I would like to know that the Market Depth Historical Datas indicator does not work anymore after 20mn of use https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Besides, I would like to know if it is possible to save a selection of indicators as a profil to import them into another chart to avoid a manual import of each of them ? Study Collections Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
